I was ripping some spruce wood today(about 2 1/4 inches thick) with a 40 tooth blade, I know it's not the best for ripping but it's what I've got. Part way through the cut, the safety pawls jammed and the saw stalled. Getting the piece of spruce out of the way ,each time when I press the start button it will power down and stop when I release the start button. Sometimes I hear a click when the blade powers down. At first, I thought I had too many extension cords and a couple of fans on the same circuit( it's 98 degrees here today). Getting the saw down to my heavy-duty cord didn't help. I read in Loring's FAQ that the Power Switch on older models was a bad design(mine's from 1993). althou mine has a black "On" button, not green. Anybody have any other ideas that I should look at? Steve
Problem with Saw or Power Switch
If I understand you correctly when you push and hold the start button it will stay on, as soon as you release it shuts off?
you need a new switch. There are no other circuit breakers, etc in the saw's system to shut it down.Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison -
You can unplug the saw motor from the switch on the BT's and just plug the motor straight to the cord or outlet long enough to test it... CAREFUL! The saw will start up on its own when you do (provided the motor is OK).Comment
I have a used switch....
My saw has died and I have been parting it out on EBay, but would sent you the switch for the cost of shipping. I'm here in So Cal. Or if you are local you can arrange to p/u.Comment
