It’s become hard to raise and lower my saw blade (BT3). Lowering it is a little easier than raising it. That said, I am getting ready to do some maintenance. I’ll be checking and cleaning the shims etc., but what I would like some information on, - is it hard to change out the spring on the blade adjusting assembly, or is this something I need to leave alone? The reason I am asking is because I no longer hear a 'click' as I raise/lower the blade. Looking at the schematic, it looks as if I can do it. Does anyone have any advice concerning “hidden things” I need to watch for as I disassemble and reassemble the blade adjusting assembly? Should the roll pin (#51 keeps spring in position) be centered through the clutch (#29)? The pin on my saw sticks out more on one side of the clutch than the other side. Both ends of the pin do have enough length sticking out to retain the spring in the proper location though. Whew! – Sorry to be so long winded! Thanks
Lynn
Ps: The numbers are referenced from the schematic in the BT3 manual
Lynn
