Help!!! I Really Should Know This
  • Bruce Cohen
    • 2698
    • Nanuet, NY, USA.
    My 3100 is probably 4 years old or something like that. Lately (past 2-3 months) I seem to be having trouble setting the blade bevel to exactly 90 deg. I can get it dead on (using a Starrett square, but as I swing the locking handle, the blade moves (kind of a jumping motion). The movement is always there, but the amount is random.
    I used to hold the hight adjustment wheel as I rotated the locking lever and that used to work all the time. Now that trick doesn't seem to work all the time. I can feel an engagement or dis-engagement as I start to rotate the handle, and that's just when the blade moves.
    I've blown out the guts with compressed air, used candle wax on the gears, backed out the bevel stop screws, althoiugh this only happens at 90 deg. setting, anywhere from 45 deg to about 85 deg works fine. Problem is I don't do much cutting at these angles.
    I do get the blade to 90 deg, but it's getting to be a PITA, and I'm now at a loss for what to do.
    If I could afford it, I'd just part out the 3100 and buy that new 10" Rikon with a sliding table, although the old lady would probably kill me even if I was able to do so.
    So I guess there's gotta be a fix floating out there.
    Somebody please help.
    Bruce
    Samuel Colt did"
    Bruce,
    Not sure if this is the same issue but I had problem getting mine to move properly when setting the bevel angle a while back. after puzzling over this for a while I realized my problem was something really simple and stupid. The screw in the center of the main adjustment wheel was loose and therefore the clutch mechansim did not engage properly. I tightened it up and everything was fine.
    As I said I am not sure if this is the same issue but thought I would share.
    • Bruce Cohen
      • 2698
      • Nanuet, NY, USA.
      Hey Jon,
      Thanks for the tip, I got a chance to try it and Eureka. it works.
      And considering you were the only one to reply...
      I guess that everyone else was waaay too caught up in trading jokes on Around the Coffee Pot.
      Thanks guys and Really Thank You Jon.
      Bruce
      Samuel Colt did"
        I didn't answer because I didn't have the answer, Bruce...
        • just started
          • Mar 2008
          • 642
          • suburban Philly
          Same here, I don't have a BT so I have no idea. I will say Bruce is right about this starting to become joke central recently, and a lot less ww talk.
            • 8807
            So THAT is my problem. Thanks! I have been extrapolating the difference in where it jumps to versus where I have to start "setting" it. I usually get it on the third try pretty accurately.
              Hey Jon,
              Thank You Jon.
              Bruce
              Youre welcome
              • dkerfoot
                • 1094
                • Holland, Michigan
                Couldn't possibly have had to do with the non-descriptive title...
                Doug Kerfoot
                KeyLlama.com
                • Russianwolf
                  • 3152
                  • Martinsburg, WV, USA.
                  • One of them there Toy saws
                  Or that some of us haven't had it do that, so we hadn't a clue.
                  I was going to suggest doing a good clean-up. I know I need to get all the dust out of mine.
                  Lakota's Dad
                  • Bruce Cohen
                    • 2698
                    • Nanuet, NY, USA.
                    Dkerfoot:
                    Your sarcasm isn't really appropiate or desired.
                    Bruce
                    Samuel Colt did"
                      snip
                      Bruce
                      Dkerfoot:
                      Bruce
                      Hey lighten up! As if yours is appropiate? Just because you only got one direct answer in reply that just happens to have solved your problem is no reason to cast scorn on those that wish to post more in the OT forum.
                      Like many others I read your post and did not have the "right" answer never having this problem myself. I'm not saying mine has been flawless; I think I now hold the bevel/height wheel out when ever I change functions but I do bevel cuts so rarely that I really do not remember for sure.
                      • dkerfoot
                        • 1094
                        • Holland, Michigan
                        Bruce,
                        As Mark points out, you initiated the sarcasm. When someone leads with sarcasm, I generally assume that they can handle a little bit in return. My apologies for having misjudged you.
                        My reply was intended to be helpful. Provide a meaningful title to your post and the people who have an answer and are inclined to be helpful will notice it and reply. Few of us read every post every day.
                        I am glad that I did stumble upon the post though, because now I'll know what to look for if I ever have the same problem.
                        Doug Kerfoot
                        KeyLlama.com
                        • Bruce Cohen
                          • 2698
                          • Nanuet, NY, USA.
                          Major Apology "again"
                          Doug,
                          Well once again I find myself apologizing for using my mouth before my brain kicks in. So as I try to extricate my foot that part of my anatomy I sit on, please accept my most sincere apologies for being a moron.
                          Hope this will reinstate some good will among the members of this forum.
                          Bruce
                          Samuel Colt did"
                          • dkerfoot
                            • 1094
                            • Holland, Michigan
                            Thanks Bruce. I am sorry for the role I played in it as well.
                            Have a great day!
                            Doug Kerfoot
                            KeyLlama.com
                              As I mix my metaphors, I am glad to see that our sandbox has returned to a sea of tranquility. Actually our sandbox is full of sawdust and woodchips so should we be playing in a woodbox - Hmmmmmm
