HELP BT3100 Stopped SOS SOS SOS
  • BerniePA
    • 377
    • San Tan Valley, AZ
    • Grizzly 0575
    I was ripping a 2x3 tonight and my niece was helping by catching on the other side of my workbench. The cut was almost complete when I hit a slight patch of knotty area and the saw slowed just a little and then it got through the area, but it made the rest of the cut apparently free wheeling with no power. My neice said she heard a couple of soft bangs and the lights dimmed, I was concentrating on the cut and saw or heard nothing, nor did I smell anything of burning or electrical nature.
    My first thought was the belts finally went. After stripping down enough of the machine to SEE the belts, I realized that Duh 1) they were OK and 2) even it they were broke, the motor should still run and it does not.
    I do have power through the switch since I have my router on the saw and plugged that in and the switch powers that OK.
    I am going to check the brushes tomorrow, any other suggestions, other than bad wiring between the switch and the motor? I should mention that I have bought brushes because the saw has been acting up lately by occassionaly not starting when I hit the switch, but if I turn the switch off and rotate the blade a little manually and then try the switch again, it will start -- sort of like a bad starter in a car -- which is why I felt the brushes were going and got them, just haven't had time to replace them yet.
    Do we have a source for motors if the whole motor bit the dust -- but I really don't think so (maybe wishful thinking??)
    Thanks for any suggestions.
    Bernie
    Bernie
  • BerniePA
    • 377
    • Grizzly 0575
    Never mind -- I fixed it.
    Bernie
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      What was the problem?
      • Rslaugh
        • 609
        • Punta Gorda, FL, USA.
        • None right now
        yeah - you can't stop there!
        Rick
        IG: @rslaugh_photography
        A sailor travels to many lands, Any place he pleases
        And he always remembers to wash his hands, So's he don't gets no diseases
        ~PeeWee Herman~
