I was making hte last cut of the day and the crank felt tight.
I tried to lower then raise the blade and then something slipped
the crank now spins quite easily, but the motor does not move
Without a complete disassembly, I am guessing I stripped the
motor bracket ( I saw what was probably the treads on the lift
shaft.
So, Has anyone done this before? Any chance of repairing this with
a helicoil?
Since it looks like I will be doing some major disassembly, any other
things I should check for wear/replace while I have it all apart. I
just assume buy all the parts at once.
Thanks in advance for any tips/info.
Mark
shaft.
a helicoil?
Mark
Black wallnut
