I finally got around to getting the dual miter slots for my 3100. It comes with 4 shims and the instructions say to install them to raise the table and that it should be just less than level than the main table. Even with 2 shims at each end it is still quite a way (1/16 to 3/32s) under the main table and also slightly lower at the back.
Does this matter shouldnet it be virtually level with the main table?
What has everybody else done with their install and shims?
Also do you need to align it with the blade and how do you do this there doesnt appear to be any adjustment other than some slight play in the mounting screws.
Thanks in advance
Thanks in advance
