Just wanted a gut check. The BT3000 has to move out of my garage in the next couple of weeks (the Jet is in my shop-- thanks, Jeffrey!) and there is a guy at work that is interested in buying it. I need to give him a better-than-fair price. Does this sound OK?
BT3000, ca. 1996, 13A, upgraded (rocker) switch
original blade, clean and sharp
2 dual-slot miter tables, Komatoast brackets
extra accessory table
wide rail kit
wide leg kit
outfeed table on rear rail
2 long rip/miter fences
router/jig saw kit
miter hold-down clamp
spare belts
spare shims
spare table slides and eccentric screws
2 spare plastic fence ends
spare blade washers (don't ask...)
all literature
Recently serviced (R&R, clean and lube shims; clean and lube everything else; adjust blade elevation, miter slots, miter table, and rip fence with dial indicator). Parallelism is around .001 from front to back of blade for everything, but blade runout is .007. Cuts are clean and square.
Miter table has a little wear on the ridges that lock the fence (underneath), repaired w/ JB Weld, fence locks fine.
$250, he picks it up (but I help him set it up)
Is this fair? I think I could part it out for more than that.
Dave
wide rail kit
wide leg kit
router/jig saw kit
spare belts
spare shims
all literature
Dave
