Elevation difficulties explanation
    The DC hose to my BT3100 goes down the wall and then a 4 inch flex hose goes across the floor, underneith the outfeed table/work table to the BT. I kicked the hose off unknowingly on Saturday just as I was starting to make a bunch of dust (cutting down a bunch of 2x4s for side rails for my new little trailer). When the dust started coming out of the top of the saw, I knew something was wrong and went to investigate. By then I had the hose plugged up so recovery took awhile. I also noticed that the elevation handle was quite stiff so I left it alone.
    While cleaning all the excess dust from under the BT3100 and unplugging the DC hoses, I also cleaned off the height mechanism and found what was causing it to be stiff. There was compacted sawdust at the bottom of the gears for the height mechanism. I usually blast this with a dry lube which probably cleaned it out previously but the can was low so I started scrapping it off. It would come off quickly with a penetrating lubricant but mechanicanically removing it by scraping was not real easy. Once removed (and lubed), my height mechanism was back to normal.
    I am relating this so that others will know something to check when the mechanism gets a bit stiff. This is probably not the only way this gets hard to move but it was clearly my issue this time.
  • tribalwind
    • 847
    • long island, ny.
    oh sure, NOW i find this! haha. i just posted about the very same problem with raising my blade.
    thanks a bunch, i'm gonna check that out when i get home. ! maybe a good blasting from my air compressor will do the trick eh ?
      The air compressor should work pretty well. I just cleaned mine out a couple of day ago. But I didn't use the compressor until I had most of the stuff cleaned out with a paint stirring stick and shop vac. It makes a big difference. Pulling off the side panels makes it a lot easier, and there are only a few screws to remove.
        Relocating the ground screw from the right side of the saw also makes panel removal/replacement easier.
