Hello gang,
I recently dropped my SMT - well not really dropped. I bumped it trying to avoid another object when I had it off the saw and the plastic slides broke. By slides I mean the small black plastic pieces that hold the sliding table to the base. These are installed on 3 eccentric and 1 standard screw and sandwhich the sliding flange on the base.
I hope you know what I mean. I cant remember what the actual name for them is.
I ordered more of them from order tree...and they sent me 2 packages of the lower ones. (upper and lowere are different) But the part numbers were correct. No biggie.
Question 1 - where can I get parts for the BT3100? I was told ordertree does not carry parts anymore.
Question 2 - has anyone tried to make replacements for these slides? I was thinking that there is no reason that they need to even sandwhich together and could be one piece. I was thinking UHMW or Aluminum. I could get the new ones and measure the slide gap and cut it to the same size and drill the same hole.
Question 2.5 - Your thoughts??
Thanks!
Thanks!
