hello,
i have a bt3100. i wanted to cut cut a tounge on all around the raised panels that i just made for some cabinets, and when i went to clamp a 8" tall board to the fence, i found that vertically the fence is not square with the TS. its off by an 3/16 at 8" high. how do i ajust for that.
the other thing is, if i am going to make a table top by cutting strips of wood and then jointing them, then the joints wont close up if i have made them with the TS, i will need a jointer/planer to plane the edges. the book that i was following, just shows them using the table saw and jointing the wood to get excellent joints.
second last question, how do i ajust the fence so that when i push down on the handle of the fence it locks paralell with the blade?
lastly, when i have moved the rails back and forth, how do i get them back to the correct spot so that i can just use the measurements of the rail for cutting wood, rather than keep measuring the distance from the blade to the fence all the time?
i would appreciate if someone can help me out with these issues.
