ZCTP Search
  • movnup
    • Aug 2006
    • 190
    • Seattle
    ZCTP Search
    I am looking to purchase some zero clearance plates (not manufacture my own). I looked all over on the web (ryobi / sears) and the t-nuts site which shows they sell them but no luck. Any ideas ??????
    Thanks,
    Jim Z.
  • LYU370
    • Mar 2005
    • 215
    • Streamwood, IL.
    Not sure. I got mine at T-nuts.com, checked over there and sure enough, they're not listed. Anyone know what's up?
    Andy
    • eweu
      • Aug 2006
      • 22
      • Silicon Valley, CA
      • 21829
      "22811" is the magic search term on sears.com. Here's the ZCTP:
      http://www.sears.com/sr/javasr/produ...id=00922212000
      It's $15 for two. They show up in the classifieds forum from time to time too.
      • JoeyGee
        • 1509
        • Sylvania, OH, USA.
        I have some ZCTP sets. I have them posted in the classified section. $10+shipping for a set of 2.
        • movnup
          • Aug 2006
          • 190
          • Seattle
          The sears picture has a four hole set up vs. the three on the saw. Do you have to tap them out to a four screw set up as other people described when making there own ??? I wanted the easy path to screw it down and cut cut cut away...
            Jeff anounced that t-nuts was for sale. He didn't really have time to devote to it anymore. So I am sure it is just an out of stock thing.
            • Lowell
              • 27
              • Chula Vista, CA, USA.
              • Ryobi 10” Precision Woodcutting System, Model BT3100
              The BT3100 has four threaded holes; the BT3000 has two threaded and two smooth-bore holes. The Ryobi ZCTP package (part no. 4070333) includes a one-inch long thread-cutting screw to tap the two smooth-bore holes on a BT3000, along with four flat-head screws to secure a ZTCP.
              Cheers,
              Lowell
              • movnup
                • Aug 2006
                • 190
                • Seattle
                Thanks everyone ... I did a search and found OEM on e-bay. Hopefully they have the thread cutting screw that Lowell was describing. I also sent a PM to Joey ...
                • gmack5
                  • 1972
                  • Quapaw, Oklahoma, USA.
                  • Ryobi BT3000SX & BT3100
                  The Screw that's included with the ZCTPs is a "Thread Forming Screw", not a Thread Cutting Screw.
                  The difference is that the Thread Forming Screw does NOT make chips like a Thread Cutting Screw does. The Screw is Tri-lobular, with an #8-24 x 1" thread form that EXTRUDES material to form the threads.
                  You could cut your own threads if necessary, using a regular Thread Cutting Tap, but it would make shavings that you would have to clean up to protect the guts of your Saw.
                  George
                    A set of taps from Harbor Freight are nice to have anyway and will take care of this in a few minutes. I thought the threads on my BT3100 were partially formed - the hole did not seem smooth but it did not readily take a screw either. A quick run through with a tap and everything was fine. You can also get individual taps of higher quality at Lowes or Home Depot.
                    • Stytooner
                      Roll Tide RIP Lee
                      • 4301
                      • Robertsdale, AL, USA.
                      Aren't they 10-24 thread, George? I think thats the right size.
