New to using the BT3100 TS and have a few questions which I haven't found clear answers to when I search the threads. I recently aquired two Dual Slot Miter Table inserts for the BT3100, and trying to decide if I really need to keep the 2nd ....
1) My experince in the past has been with TS with only one miter slot, other than a sled that would use both slots on the left side, what other uses would one have to use both at the same time?
2) I've seen a lot of talk and reference to using a second dual slot on the right side, again other than a sled, what advantage does it provide on the right side (other than filling the void in the table and making the surface larger)?
3) With the way the router table is designed on the BT3100, it seems to me logical that if mounting a dual slot miter on the right side, it should be on the outside (as in the far side of the router insert) in order to allow it to be used with the router ... but then would likely be almost useless for anything else.
4) Does anyone have some pictures that show uses for the dual slot on the right side (other than a sled)?
I did a search on the forum, but a lot of the threads came up with pictures missing ...
Thanks,
Thanks,
