Yes to both!
Bruce,
Short answers to your questions:
Are you obsessed? - Yes.
Is 0.001" out of allignment OK? - Yes.
The variance that Lonnie calculates is in the proximity of 0.01" for any type of blade except "Hollow ground planer". That is 10 times more than you have. If you have and use a "hollow ground planer" blade - than you can worry. Hollow ground planer is a blade that has the kerf same thickness as plate. Those blades more often than not have no carbide teeth, steel only.
Bruce,
