Can I rip 3" poplar on my BT?
  • JoeyGee
    • 1509
    • Sylvania, OH, USA.
    This may be a dumb question, but I have only used my BT a couple times so far--on 3/4" pine. I need to make some posts for my daughter's bed, which will be made out of 3" poplar. I just want to make sure I am not going blow the motor or the belts.
    I am making the NYW Trundle bed. I made one for my son, but at the time I had a Grizzly 1023S, which had NO problem with 3" poplar : )
    No offense to my BT, but I sure miss that saw...
    • 8790
    The BT can cut 3 full inches without a problem. However, you might need to feed it a little slower than you would on the Grizzly. This is a relative thing. Some people can judge the proper feed speed by the sound of the motor, but some have difficulty with that.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      You might want to consider a getting a 24T ripping blade for thick materials anyway...always handy to have and a bit easier on the motor.
      • Wood_workur
        • 1914
        • Ohio
        • Ryobi bt3100-1
        make multiple passes- but with a cut down riving knife.
        Alex
          I did 3 1/2 inch oak with the stock blade but had to go pretty slow. I now use a Freud 24 tooth ripping blade for the thick stuff. It goes a bit quicker but the stock blade will do the job. Poplar should be easier.
          • meika123
            • 887
            • Advance, NC, USA.
            As I posted on another forum, I use a Freud 24 tooth blade for ripping. However, the stock blade should do it, no problem. If it doesn't, I think I would get rid of it. (Just kiddin )
            Seriously though, I have ripped 3 1/2" stock in one pass with my stock blade. Like the other guys said, just feed it a little slower.
            Dave in NC
            • bigsteel15
              • 1079
              • Edmonton, AB
              The riving knife shouldn't interfere with non-through cuts if adjusted properly.
              Although I have the SG on mine so I could be wrong about the stock unit.
              Brian
              Welcome to the school of life
              • JoeyGee
                • 1509
                Well, I did it.
                I did it with the stock blade--just too impatient to get a new blade, I guess. I did do it in two passes. I tried to do it all at once, but it complained like a 16 year-old without a car.
                Thanks for all the replies.
