Anti-slip miter fence
  • paynea
    • 30
    • Massachusetts, USA
    Good morning,
    I've finally almost finished assembly of my BT3100-1 purchased when HD was offering them for 150 after rebate. It's on a $29 Ridgid Herc-U-Lift thanks to the advice of this forum, and I have painted the storied 'red line' already.
    I've read of using relatively fine-grit self-adhesive sandpaper on the SMT miter fence (or on the face of a more traditional miter guage). Can anyone think of drawbacks to using a light spray of Plasti-Dip instead (http://www.plastidip.com/consumer/index.html)?
    It's an aerosol version of the liquid rubber used to dip tool handles, etc. I have a can of the clear version, and was thinking of spraying it on the cast iron face of the guage from my Grizzly G0555 band saw and the BT's miter fence. I can't forsee drawbacks for the Al fence, but am a bit uncertain of it's suitability to machined cast iron.
    Should I just quit trying to get fancy and go with sandpaper after all, or does an invisible anti-slip finish sound plausible? I welcome your feedback, thanks in advance,
    Adam
  • bigsteel15
    • 1079
    • Edmonton, AB
    My only concern would be getting an even surface and staying even as the material wears off, as it always does.
    Sandpaper wouldn't have either problem if properly affixed..
    Brian
    Welcome to the school of life
    • Tequila
      • 684
      • King of Prussia, PA, USA.
      That plastidip goes on pretty thick from what I remember. It will definitely stop things from slipping, but you'll need to doublecheck your angle settings every time you use the miter gauge. There's no way you'll get a flat, even finish out of it, so your 45degree miter might become 43 or 46 degrees.
      -Joe
