New BT3100 Owner!
  • Cabotcat
    • Oct 2004
    • 10
    • Calvert City, KY, USA.
    New BT3100 Owner!
    Disclaimer: I live in Gilbertsville KY and travel to Nashville TN for airport use.
    Crazy purchase experience. Following this great site for years. Finally had the need for the BT3100. Flew to San Antonio from Nashville this morning. While in SA it dawned on me that I might be able to find a new BT in Nashville (numersous stores). Returned to Nashville this evening after my meeting. Ripped a page out of the phone book at the Nashville airport. Called HD and determined that the Brentwood store has one new in the box. Drove 20 minutes in a 1997 Buick Riviera. Bought the saw. Went to load and realized it would not fit anywhere well. Put one corner in the trunk and tied the **** out of it. Drove 55 mph for 2.5 hours from Brentwood TN to Gilbertsville KY. Got the new saw home same and sound.
    As 10cc once stated " the things we for love"
    Welcome to the forum, Cabotcat. Yeah, we do some crazy stuff, don't we. Enjoy the BT, it's a fine saw.
    ken
    • gary
      • 893
      • Versailles, KY, USA.
      Hello and welcome from a fellow Kentuckian in Versailles.
      Gary
      • Ken Weaver
        • 2417
        • Clemson, SC, USA
        • Rigid TS3650
        Congratulations - be safe!
        Ken Weaver
        Clemson, SC
          Where there is a will there is a way. Welcome to the forum.
          • gmack5
            • 1972
            • Quapaw, Oklahoma, USA.
            • Ryobi BT3000SX & BT3100
            Welcome Cabotcat,
            Congratulations on the acquisition of your BT3100 and welcome to the "family".
            One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding proceedure, so you MUST keep them in sequence.
            Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
            entire saw.
            Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
            You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/
            The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
            One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
            This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea.
            One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
            A good Carpenters Square will cost you quite a bit of money, $40 - $75, or more.
            I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
            Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
            George
              • 10481
              Welcome to the Asylum!
              • Wood_workur
                • 1914
                • Ohio
                • Ryobi bt3100-1
                WELCOME!!!
                and, how could he possibly be safe, after that crazy trip getting it home???
                J/K, we would have done the same...
                Alex
                  Welcome aboard.
                  • Cabotcat
                    • Oct 2004
                    • 10
                    Thanks so much to eveyone, certainly to gmack5 for the excellent newbie tips.
                    The saw must wait until Sunday to assemble. With the 4th of July fastly approaching, the wife has me tied up until then. Give a little get a little I say.
                    I have unpacked the box and read the instruction manual. I actually cut the english version off with a razor knife and seperated each page. I then used a 3 hole punch and inserted it into a 3 ring binder. This will make it much easier to access come assembly time.
                    Again - thanks to all.
