I have been having a problem with aligning the blade so that it is exactly 90 degrees to the table top. I have used carpenter squares and a newly purchased engineer square and they seem to give different results, depending on where the squares are placed.
After much pondering over a couple of days and about twenty cups of coffee I realized that the top of the table is not perfectly flat in that some items (such as the accessory table, SMT, and added miter-track tables) are not exactly level with the fixed parts of the table just to the right or left of the blade. Of course, the Ryobi ZCTP is not even close to level. And, I have seen it written that the SMT is designed to be slightly (0.2 in, or so) above the main table.
Question: What is the best reference point to use for aligning the blade and leveling any add-ons to the table top? And, when doing a cut, which part of the table should support the piece being cut to ensure an end that is as perfectly squared as possible.
Thanks for the help, again!
