I finally realized (after only 6 years
) that my SMT gets in my way when ripping. With that thing sticking out 6 or 8 inches in front of the saw, I find I have to lean over more than a comfortable amount to maintain control, and complete a cut. And, since I've had a SCMS for the last few years, I'm not using the SMT much, anyway.
So, I made a filler board the same width as the SMT, and mounted it to the front and back rails using Al angle, and t-studs (t-nuts with 5/16" studs welded in, from Jeff's T-nuts). It fills in the spot, between my acc. table and the saw table, for the SMT, which I plan to store off the saw.
Now, I'm wondering if I'll use my SMT even less, now that it's off the saw. I made the filler board as easy to put on and take off as possible -- can't imagine it being much quicker. But it won't be as quick to set up the SMT as if it were still on the saw.
I bet there'll be some interesting things I can do with a blank board just to the left of the blade. Since it was quick and easy to make, I won't be hesitant to drill a hole here or there to attach a fixture. We'll see...
Any thoughts from off-board SMT storers?
Regards,
) that my SMT gets in my way when ripping. With that thing sticking out 6 or 8 inches in front of the saw, I find I have to lean over more than a comfortable amount to maintain control, and complete a cut. And, since I've had a SCMS for the last few years, I'm not using the SMT much, anyway.So, I made a filler board the same width as the SMT, and mounted it to the front and back rails using Al angle, and t-studs (t-nuts with 5/16" studs welded in, from Jeff's T-nuts). It fills in the spot, between my acc. table and the saw table, for the SMT, which I plan to store off the saw.
Regards,
