Used BT3000
  • brunski
    Used BT3000
    Hi,
    I became an enthusiast of the BT3000 by reading these forums, eventhough I didn't own one. Well, looks like I hit the lottery and found a BT3K in a yard sale for $50 . My question is, what is the safest way of cleaning the top of the table. Seem that the previous owner loved to paint and stain on top of this thing. Also where can i find the rip fence? It was missing. Other than that, it runs beautiful, it just needed some cleaning and oiling.
    Thanks,
    Brunski
    Welcome to the forum, Brunski and the great score on the saw. Check the member classifieds for a fence. The BT3K top is aluminum so mineral spirits will take care of the paint safely. I'm sure qmack will post shortly with a ton of good info.
    Enjoy your saw.
    ken
      Brunski,
      Great score! Welcome to the friendliest board on the Internet.
      • brunski
        Thank you guys
        Now I really need to find a nice used 'shark guard' and few other thing$
        • gmack5
          • 1972
          • Quapaw, Oklahoma, USA.
          • Ryobi BT3000SX & BT3100
          Welcome to the Family
          Welcome to the "family".
          One of the first things you need to do, after you get your BT3000 Table Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual.
          Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
          An accurate Carpenter's Framing Square is almost a myth!
          A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30-60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. If you get a 45 degree triangle that is 10", or more, then notch out the right angle corner so that you have about 8" exposed as a straight edge so you don't contact the teeth of your Saw Blade.
          That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
          Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
          You might also want to check out the "FAQ" in a "sticky" at the beginning of the Getting Started Forum:
          http://www.bt3central.com/showthread.php?t=19968
          It'll answer a lot of your questions.
          Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
          The reason is simple enough, most of them contain Silicones that will make your projects difficult to finish.
          Silicones repell liquid, making "fish eyes" in your finishes, this will cause you to remove the Silicones from your project and start over. That stuff (Silicone) migrates all over every where, don't ask me how, it just does.
          If you put it in one place, eventually it will be all over the entire saw.
          Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax (parafin) for the Raising/Lowering and Tilt mechanisms below the table top.
          Do NOT use "oils" as they will get sticky and attract Saw Dust and "gum up" the mechanisms under the table top.
          Use either Johnson's Paste Wax, Minwax's "Finishing Wax" or Butcher's Wax on the working surfaces, table tops (All three of them) and the Rip Fence.
          You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/index.php?page=articles
          The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
          One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
          This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea.
          One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
          Another "problem" that I've solved is as follows:
          Problem: The Miter Fence does not move smoothly when making an Angular Adjustment or when installing/uninstalling the Miter Fence.
          There is a Grove on the bottom of the SMT that the Head of a 5/16-18 Machine Screw rides in, it's the "Clamp" Screw that you're using when you tighten the Knob to lock the Miter Fence in place.
          Uninstall the Miter Fence and rub Candle Wax (Parafin) on the Hexagonal Faces of the 5/16-18 Clamping Hex Head Machine Screw, coat it liberally, so that the Parafin will be spread over the Working Surfaces that the Bolt Head rides in. You may also want to coat the Sides of the Slot that the Clamp Screw passes thru.
          This should make the Miter Fence move much smoother thru it's range of motion, as well as make it much easier to install/uninstall.
          George
