Hi all,
My belts broke on my BT3100 so following the great directions from this site I took it apart and installed new belts. The belts went on with just a little bit of struggle. The problem is reinstalling the shims. I put the flat shims on either side of the arbor then put the spring shims on the guide holder. I'm pretty sure these are on correctly per the great pics by Black Walnut. The four screws that hold the guide holder to the motor go in just fine. When I try to screw in the two screws that connect the guide holder to the bearing plate they don't quite reach. What am I doing wrong.
Thanks in advance.
Thanks in advance.
