I have had a pair of rail extenders for sometime.I know there has been much said here about the wide table. I havent been able to find the answer so I will bore you all and ask anyway:
Is there ant limitation as to the orientation of the extended raile ie. I'd like to have about 30"' of rail to the right of the blade and the rest to the left side. Wonder if you can do this and if there are any pit falls if you do?
I'm a lefty and have my saw set up backwards from most of you, but that just has to be, I do not feel safe with everything backwards.
Brad
Brad
