My blade depth adjusment locked up on my BT3000. I suspected shims, but since I'd installed the BT3100 upgrade, I was pretty bummed. I loosened the guide holder, jiggled everything around, (flat shims fell out, of course), still couldn't get the blade adjusting handle to budge.
Finally noticed the roll pin (51) had slipped part way allowing the spring (40) to slide forward over the end of the roll pin preventing the roll pin from engaging the clutch (29). I did a search to see if anyone has had this problem and for the most part, it seems people have had difficulty getting the roll pin to move at all. I can slide mine with my fingers. I pryed the spring back, slid the roll pin into place, dry lubed the shaft, replaced the shims, guide holder, etc. and now everything is working fine.
Has anyone had this problem? I'm afraid my roll pin will shift again.
Any suggestions?
Thanks
Any suggestions?
Thanks
