Water Damage Question
  • emjr
    • 21
    Hi, I'm new here.
    I have a BT3001 in my improvised basement shop. I've also got a sump pump. Yesterday, the discharge line got a pinhole leak, which laid a fine spray of water over part of my saw (front rail, rip-fence clamp, front edge of table). I got the water off and took care of the leak, but I observed a bit of rust on some of the steel parts of the fence clamp mechanism. Looks to be surface rust only, and the duration of the spray could not have been more than 24 hours. Do I need to take the mechanism apart, or will a thorough blowout with compressed air dry things out sufficient that I won't have to worry about serious damage? I appreciate any insight anyone may have.
  • gmack5
    • 1972
    • Quapaw, Oklahoma, USA.
    • Ryobi BT3000SX & BT3100
    Your safe!
    To my knowledge, there are no steel/iron parts on the Fences (either one of them), except for some screws and maybe a steel pin that is the Axle for the roller at the back of the Rip Fence.
    If it were me, I'd dry the parts thourology, then coat them with WD40 to prevent further Rust. Do not get WD40 on the working faces of your Fences.
    If you think the steel parts have water in a location where you can't dry them off without taking the Fence apart, the you might want to take it to a service center and let them disassemble the Fence. Especially if you don't feel comfortable doing that kind of thing.
    George
    • emjr
      • 21
      Yes, it's the screws/bolts I was worried about. Big load off my mind-thanks a lot!
      • gmack5
        • 1972
        Welcome to the "Family"
        Welcome emjr,
        Congratulations on the acquisition of your BT3100 and welcome to the "family".
        One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
        Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
        The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
        Silicones repell liquid, making "fish eyes" in your finishes, this will force you to remove the Silicones from your project and start over. That stuff (Silicone) migrates all over every where, don't ask me how, it just does. If you put it in one place, eventually it will be all over the entire saw.
        Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top. Then use either Johnson's Paste Wax, Minwax's "Finishing Wax" or Butcher's Wax on the working surfaces, table tops (All three of them) and the Rip Fence.
        You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/index.php?page=articles
        The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
        One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
        This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM.
        Performing this PM on a monthly basis would be a good idea.
        One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
        A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30-60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner.
        That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
        Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
        You might also want to check out the "FAQ" in a "sticky" in the Getting Started Forum:
        http://www.bt3central.com/showthread.php?t=1699
        It'll answer a lot of your questions.
        George
        • emjr
          • 21
          Thanks a lot! Looks like plenty of useful info.! I appreciate the welcome, too.
          • Wood_workur
            • 1914
            • Ohio
            • Ryobi bt3100-1
            Definatley.
            Welcome to the forum, have fun, and be safe. If the saw doesn't work as well as it did, or the rusts screws it up, take it back to Home Depot, and make an exchage.
            Alex
            • just4funsies
              • 843
              • Florida.
              Don't overdo it with the WD40 or any other lubricant, because if it gets on the wood you're working on, you may have some trouble with the finish.
