Just got a copy of ShopNotes Vol 15 # 86 with an article about how to make a thickness sander that is powered by your table saw. The base is made to fit in the mitre slot and the sanding disk is run by power from a belt that runs from a pulley they say to put on your saw arbor instead of the blade. The belt comes up through the blade slot.
Would this work with a BT3100? Any thoughts?
