I want to thank all of you for the great information you have provided on this site. I am very new to a table saw so I am learning on the fly so forgive me if my terms are wrong, still learning. I purchased my BT3100 a couple of months ago and while looking for some accessories I found this site yesterday, needless to say this was much more interesting than actually working so I read a lot of the information. Last night I went home and mounted my small router to the accessory table, using the template supplied in the articles section. I then created a small fill in table between the blade and the accessory table, using the mounted router to cut a slot for a yet to be built miter gauge. I then created a router fence that can be placed over the guide arm (?). Created some feather boards. Bascially I played in the shop last night. The one thing I did realize last night was the NEED for a dust collection system. Needless to say everything is covered in a nice layer of saw dust right now. I am going to keep experimenting with different projects and creating some of the jigs listed on this site, my hope is that next winter when I finish my basement I will have enough skill to create some custom cabinets for the bar area. Thanks again, I will be refering to this site a lot in the future
Great information on here
Welcome Mr. Strubel,
Congratulations on the acquisition of your BT3100 and welcome to the "family".
One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
If you put it in one place, eventually it will be all over the entire saw.
Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top. Then use either Johnson's Paste Wax, Minwax's "Finishing Wax" or Butcher's Wax on the working surfaces, table tops (All three of them) and the Rip Fence. Do NOT Wax the Front and Rear rails or the Miter Fence. As a mater of fact, you may want to glue 220 grit sand-paper to the front face of the Miter Fence, cause you don't WANT things to slide on there.
You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/index.php?page=articles
The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: http://www.bt3central.com/articles/l...sp?ArticleId=7
This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30-60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner.
That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
You might also want to check out the "FAQ" in a "sticky" in the Getting Started Forum:
http://www.bt3central.com/showthread.php?t=1699
It'll answer a lot of your questions.
It's a line that extends the line-of-sight from the saw blade to the front edge of the table to remind you NOT to let your Miter Fence or your FINGERS get in the way of the saw blade. Just put red paint, nail polish, or what ever, in the grove that extends towards the operator from the front edge of the saw blade.Stop thinking why you can't and Start thinking how you CAN!
George -
Welcome to the group. Be safe and enjoy your new saw.Monte (another darksider)
http://community.webshots.com/user/monte49002Comment
