Mitre Slot Table Instructions
  • mmacintyre
    • 20
    Hi,
    I am trying to install the mitre slot table on the left hand side and do not have a copy of the instructions, would someone be able to scan a copy and sent to me or would someone be able to explain how to setup the rails when the table is attached. It seems the rails will have to be moved over and the scale on rails will not line up correctly, off by the width of the slot table, is this the case or am I doing something wrong? Once again thanks for the help in advance.
  • Martin_S
    • 29
    Mike:
    Take a look at
    http://oneworld1.inetu.net/manuals/i...-1_232_eng.pdf
    This is a PDF of the BT3100 instruction manual
    Martin
    • mmacintyre
      • 20
      Thanks Martin,
      I am actually looking for the instruction manual for the mitre slot table from accessory kit,
      thanks,
        I've got it
        PM me with an email address and I'll send it to you.
          Sending the pdf from ryobi's website.
            Originally posted by mmacintyre
            Hi,
            OK, since you have the email function disabled, go to Ryobitools.com and search via 4060310 (model # and pdf name).
            • mmacintyre
              • 20
              thanks for the link, I have now enabled the email option, sorry didn't know I had it turned off.
              • mmacintyre
                • 20
                From looking at the instructions, it appears the scale (ruler) on the rails can not line up correctly when the mitre slot table is installed, as the rails are not long enough to house bothe the SMT, and MST on the left hand side. Does anyone have any input? thanks,
                  It works fine...
                  You just have to move the reticule from the right side of the rip fence base to the left side. There should be a mounting hole for this purpose on the left side.
