I know this question has been asked before, however I can't seem to glean a sure answer from my forum searches. Any advice would be helpful.
Problem: I can't raise the blade on my BT3100.
Symptoms/Details: Splitter is off the saw, blade lowers fine, blade angle adjusts fine. The blade had been getting harder to raise, now it will not raise at all and the adjust knob just turns with no result. A while back I cleaned and dry lube the gear system which didn't seem to help much then. I have inspected the gears assembly again and it appears not to be stripped. It acts like the adjustment knob is not turning the shaft, the knob spins with heavy resistance when trying to raise the blade.
