I just setup a RE180PL router on my accessory table. The router shaft/bit shows some sideways motion that appears to be due to clearance in the router plunger rods. I have made sure that all attaching screws are tight to table and router base. I never had a router table before so I am not sure what is reasonable movement. Is this normal for a plunger router mounted on a router table?
I would think that a router bit should be as stable as possible in order to provide a smooth even cut.
