I decided to thoroughly clean and lube my saw. I disassembled the entire blade elevation/tilt and motor assembly. While I had it apart, I thought about ways I could stop the clicking when lowering the blade. I ended up simply bending the end of the spring that rides against the roll pin used to engage the blade elevation/tilt mechanism. I reassembled everything this afternoon, and the saw elevatation works smoother and quieter than ever.
No more clicking. The spring on the left in the picture below shows a slignt bend at the end, which creates a smooth transition in both directions.
