Kreg Deck Jig
  • jAngiel
    • Oct 2003
    • 561
    Kreg Deck Jig
    Has anyone tried building a deck with the Kreg Deck Jig? Lowes has them on clearance for $29.99 and I was thinking on getting one to add a deck around the pool with hidden fasteners.
    James
  • Cochese
    • Jun 2010
    • 1988
    $30? See ya.
    • unknown poster
      • 219
      I just looked at the pics on the Kreg site. Is each board only held to the joist by a screw through one edge? If the board cups, won't it pull up the unsecured edge?
      • Cochese
        • Jun 2010
        • 1988
        Watching the video, it's done on both sides. Better pictures would have helped on the site.
        • tommyt654
          • Nov 2008
          • 2334
          Only problem with these is that it still lends to board cupping and you wind up with a nail in the center to hold that down, Waste of money IMO.
          • gerti
            • 2233
            • Minnetonka, MN, USA.
            • BT3100 "Frankensaw"
            I wonder how it compares to the CAMO tool:
            http://www.amazon.com/CAMO-Marksman-.../dp/B004W3CUOU
            I liked that one a lot when I saw it on TOH.
            • jAngiel
              • Oct 2003
              • 561
              The CAMO one looks pretty good too but I like that the Kreg has guides at an angle for when it's against a wall or you are butting two planks together on a joist. Although for the two butted together you can just sister another support board under so each has its own 2x to attach to.
              I wonder if it would be better to put the cup down so that edges will be held down with the screws. I was considering vinyl deck boards since mine will be around the pool area so the cupping issue probably does not come into play.
              James
                I put trex on my outdoor deck 5 or more years ago. It doesn't cup. I just face screwed it and I think it looks fine. The composite material contracts around the screw head some to partially hide it. You could edge screw it too, I suppose. Kreg is a pretty good brand.
                • JSUPreston
                  • 1189
                  • Montgomery, AL.
                  Still $40 here in Montgomery, AL. Picked up a kit anyway. Didn't want to miss out on getting it at all.
