Cheap Tracksaw option
That's my setup, too, except using 1/2" MDF for both tthe base and the fence. Work's like a champ.I use one like this too but with one modification. Assemble the straight edge, then drill few small holes and attach the straight edge to a strip of masonite. Then take your circ saw and trim the masonite. You get a tool customized to your saw. Masonite takes out all the play if the orginal edge had it and you no longer need to measure 6-1/8" distances to clamp. Since you used your saw to trim masonite - the edge of masonite is exactly where your blade is. Just mark your cut in couple points, line the edge of masonite with the marks and clamp it.
JRJRComment
