Freebie from Bosch
  • tommyt654
    • Nov 2008
    • 2334
    Freebie from Bosch
    Go here, http://www.boschjoethepro.com/REGIST...OIS-offer.aspx , and register for a free universal adapter for your oscillating tool using this code, code OISR10
    Thanks to the gang at Woodnet
  • MBG
    • Apr 2003
    • 945
    • Chicago, Illinois.
    I get this:
    The tool you identified has no need for the adapter, but we are able to still provide you with a Bosch OSC312F blade. The blade will be shipped to you in the coming weeks.
    OK - you need to pick another make other than BOSCH
    • sweensdv
      • 2873
      • WI
      • Baileigh TS-1040P-50
      Thanks Tommy,
      This is the message I got;
      "Thank you for registering for the free OIS adapter and blade offer found in Remodeling and JLC, Woodshop News and Popular Woodworking magazines. You will be receiving an adapter and Bosch OSC312F blade in the coming weeks."
      • parnelli
        • 585
        Kinda looks like it adapts that funky Bosch circle/plus sign mount to the standard ring of holes mount.
        Does it have any benefit if you don't own a Bosch??
        • Stytooner
          Roll Tide RIP Lee
          • 4301
          • Robertsdale, AL, USA.
          You would be able to use Bosch blades?
          I know they make the best jigsaw blades.
          I haven't yet worn out any of my HF blades though. Not sure how much better Bosch blades would be.
          • Mr__Bill
            • 2096
            • Tacoma, WA
            Thanks for the link.
            so how many of you used your oscillating tool to carve the pumpkin?
            • geopilot
              • 106
              • Lexington, KY, USA.
              This explains the use and need for the adapter quite well:
              http://www.coptool.com/blog/2010/09/...scillatin.html
              • volozhin
                • Jan 2010
                • 12
                Why do I get that it's an invalid code?
                • sweensdv
                  • 2873
                  • WI
                  When you enter the code are you entering a zero instead of the letter "O" at the very beginning? Same thing at the end except it should be the number "0" there and not the letter "O".
                  • conwaygolfer
                    • Jun 2008
                    • 371
                    • Conway, SC.
                    I tried numerous times switching the 1 for an i, etc., and it finally accepted it. Don't know why? But it worked after awhile. Keep trying.
                    Conwaygolfer
                    • TomBar
                      • 78
                      • Rexford, NY, USA.
                      Thanks for the link. Claimed one for me.
                      • DustyandLefty
                        • 74
                        • Almost West Virginia
                        • BT3000 w/ side and rear tables on wheels, BT3100 portable spare, old Delta contractor's
                        Great Pumpkin Tool
                        Thanks for the link!
                        I copy+pasted the code into the box and it worked first time.
                        Yes, I carved faces into about 20 pumpkins with the Dremel multi-max and the standard straight wood blade in October. Works really slick on straight cuts and for chiseling out details. For curved precise cuts though I used a hand-held jig saw with a narrow blade.
                        I had a lot of fun, and it was way safer than using the old steak-knife method.
                        It will be awhile before I want to smell pumpkin juice though.
                        Dusty and Lefty
                        • Dolsie
                          • 21
                          Invalid code
                          You get the invalid code because when you copied and pasted it, it included a blank space at the end. At least that was the deal for me.
                          • JSUPreston
                            • 1189
                            • Montgomery, AL.
                            Got mine last night. Got the adapter and a blade. Looks like I don't need the adapter, but will hold onto it anyway. If the Bosch blades last longer than the HF model, and are priced about the same, I'll start using the Bosch instead. I seem to go through the HF blades very quickly.
                            • Cochese
                              • Jun 2010
                              • 1988
                              Can't remember if I signed up for this or not.
