multi function tool
  • herb fellows
    • New York City
    multi function tool
    I just went to HF to see this, as everyone here has given it high marks. It was $39, but right next to it they had one for $59.
    It seems this is a variable speed model, with 10k-20k oscillation range? I'm not sure how something that starts at 10k qualifies as variable speed.....The guy said they only had it for a month or so, so I'm assuming you all are talking about the 'old' one? The only other difference I could discern was the case.
    Anybody have any insight into the new one? Do you think multiple speeds is of use?
  • Photojosh
    • Aug 2009
    • 174
    • Washington (the state)
    Any comments you've read on the multi tool here or other places is probably the old version. the variable speed one is pretty new.
    • parnelli
      • 585
      I'm not sure I can think of why the variable would be that much better.... maybe if it toned it down from super loud to just loud?
      • herb fellows
        • New York City
        Well, I guess if you're in tight quarters and you want to sneak up on something maybe..
          Maybe the slower speed would be better for delicate applications. The single speed vibration does give your hand a decent buzz.
            VS would seem to be better on sanding and grout removal more than anything else. Full speed ahead is not always the best in these. I needed to replace tile in a kitchen remodel 8 years ago. One wall section in which I placed tile that did not have it before was very smooth. I used a VS sander on slow and it roughed up the wall much better than fast would have.
            I have the Fein and it is VS. Most of the time I kept it on "Fast". I found the VS options on tools to be advantageous, but at what price is reasonable to make it worth it to you?
            When I have a choice, I usually go for VS.
            • phi1l
              • Oct 2009
              • 681
              • Madison, WI
              ya, I would think you would use high most of the time unlessthe blade has some weird resonance at that speed that makes it hard to control, or the high speed starts burning the wood.
              • geopilot
                • 106
                • Lexington, KY, USA.
                I compared these in the store last week. The variable speed model is a little bigger and heavier, with a 2A motor. The old one (fixed speed) is rated at 1.6A. The variable speed model comes with a case to hold the tool and various accessories/blades if that matters to you. Have not purchased either.
                • herb fellows
                  • New York City
                  Ok, more power, I didn't notice that. I think the blade selection was the same.
                  • just started
                    • Mar 2008
                    • 642
                    • suburban Philly
                    Like Hank, I have a Fein. I use the VS with the contour sanders mostly as it is a little more controllable that way.
