Lacquer in SOCAL.
  • fastfoodkills
    • Jan 2008
    • 89
    • Saugus, CA
    • BT3000 bought in Y2K; Replaced w/ Steel City cast iron 3 HP
    Lacquer in SOCAL.
    Not so much a bargain alert, but wanted to advise folks around SOCAL in particular who may have had the same struggle that I was recently able to find a decent quality lacquer here the Los Angeles area sold by the gallon. This is after a couple of days searching around, being fed a lot of misinformation and finally stumbling upon a decent Dunn Edwards "Contractor's Edge 275" product. I bought the "water white" type for some shop cabinet doors and it came out great and was very forgiving considering the somewhat rushed spray session late in the afternoon (I could barely see the spray pattern and had to use "The Force" ). This was an acetone based product which I shot without thinning through a cheap HF HVLP gun. Also worth noting, a week later I met a Valspar rep who told me they produced the product for D.E. and said the biggest mistake that people can make with 275 series is thinning it - he said just use it as is. Price was reasonable with a discount - $25.00 for the sanding sealer and about the same or a few bucks more for the Lacquer. They also offer a AAA discount if you don't have an account. Also of note - they offered a white pigmented lacquer which can be tinted and a black lacquer for a special order. Has anyone here tried out the pigmented lacquers? Sure sounds like it would open up some neat possibilities as an alternative to latex.
    FFK,
    Which HF gun model are you using for the DE lacquer?
    • fastfoodkills
      • Jan 2008
      • 89
      • Saugus, CA
      b0330923 -
      It's a cheap knock-off of a SATA HVLP gun I've been coveting for years. It was even the same anodized green color. Bought it for model building 10 years ago and have had decent results with it on a car and now WW projects. There were optional nozzles available as well from the Camarillo location/parts warehouse. I highly recommend these for primers and heavier materials. Also worth buying would be the airline moisture trap (in addition to the compressor trap. This would attach at the end of the airline between the hose and gun.
      This appears to be a newer generation replacement unif which I'm unfamiliar with.
      http://www.harborfreight.com/cpi/cta...emnumber=90977
      Only complaint is that the castings are a little soft - especially the brass parts. I noticed that the nozzles and needle are already wearing despite occasional use. So far this has not presented any spatter or other issues, but I'm going to take an extra measure of caution when adjusting the needle. I will have to admit, for a cheap Chinese knock-off, this gun has performed well, but if you're looking for better quality and have the budget ($300+), I'd have to recommend a SATA.
      • Tom Slick
        • 2913
        • Paso Robles, Calif, USA.
        • sears BT3 clone
        Did you find/try any MacLac laquer?
        • fastfoodkills
          • Jan 2008
          • 89
          • Saugus, CA
          Tom,
          I have not used MacLac. It looks like they have a distributor in Hollywood so I would imagine that they at least carry the low-VOC formulas since it's under the Air Quality Management District's (AQMD) control (Los Angeles, Orange County and the denser urban areas around here). They have a nice range of pigmented lacquers from what I can see on their website. Would you recommend their 275 series (which is the one I would expect to see in this area)?
          http://www.maclac.com/stain%20colors.htm
          Thanks,
          • Tom Slick
            • 2913
            • sears BT3 clone
            I don't have any experience with it but a painting contractor I know uses it on all clear finishes. He sprays it out of an airless sprayer with great results.
            I'd also guess that you'd see the 275. It looks like they also recommend not to thin.
            • fastfoodkills
              • Jan 2008
              • 89
              • Saugus, CA
              Just finished the article "Lacquers for Wood - Then and Now" on their website. Found it very informative - some topics included pre-catalyzed vs. post-catalyzed and where you would want to use each type and overviews of the wood lacquering process.
