PC 342 - Quarter Sheet Sander --> $25.99
  • footprintsinconc
    • 1759
    • Roseville (Sacramento), CA
    on my way home i stopped to pick something up and noticed that they had four PC342 quarter sheet sanders for $25.99. YMMW
    EDIT: IT IS AT LOWES! MAN, MY MEMORY IS FAILING ME!
    omar
  • chrisk
    • Jan 2008
    • 61
    • Mankato, MN
    • Craftsman Professional 21829
    Where did you stop? Home Depot?
    • footprintsinconc
      • 1759
      Dang it! LOWES
      this deal is even better if you use the $10 off coupon on $25 or more purchase.
      omar
      • garymuto
        • Aug 2007
        • 194
        • Encinitas, CA
        • Delta Cabinet Saw
        Got the coupon. I'm going to check it out tonight and see if I can find the sander.
          FWIW while I usually use my ROS I do sometimes need a regular square edged sander (a lot of the time I will just use a sanding block to get into corners).
          You can pick up one at HF for usually around $8 when on sale (which it frequently is).
          Like this one
          http://www.harborfreight.com/cpi/cta...emnumber=40070
          I know its not a PC but for the amount I use it it works just fine.
          • garymuto
            • Aug 2007
            • 194
            • Encinitas, CA
            • Delta Cabinet Saw
            Thanks for the heads up. The price was ~$32 in my area, but with the $10 visa coupon it was too good to pass up. I have an old 1/3 sheet sander thats wearing out and has no dust collection so this was a good opportunity for me.
            • stormdog74
              • Mar 2007
              • 426
              • Sacramento, CA
              Around $37 in my area ($27 with the coupon), so a good deal overall for something I have been needing. Thanks for the tip.
              • footprintsinconc
                • 1759
                the lowes that i went to originally, still has four for the same price. it seems like the product didnt move?
                omar
