Delta 35-7670 8-Inch Stacked Dado Set $99 Amazon Today only
Tags: None
Don't forget you'll have clearance problems with 8" stacked dados on a BT saw, but larger saws are OK. -
AFAIK, it's the same as the DW7670. It's better than my SD208 was, plus has a nicer case and nicer shim stock. It'd take the Freud SD508, 506, or 608 to eclipse the 7670 set IMHO.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.Comment
Footer Ad
