25% off Freud@amazon/SD206 $63.75
  • Andrew Benedetto
    • 1071
    • SoCal, USA
    http://www.amazon.com/gp/product/B00...CCSHAPD1T8C8C6
    I went thru link here at the top of web page,but not sure if it will give credit to site.
    I paid $65 for one from a member's classified ad here, thinking that was cheap. This is even less.
    Most Freud is on sale;
    Enter code FREUDIO8 at checkout
    Andrew
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    Double check your total before finalizing any order under this promotion. I tried to order another Freud blade that also stated that a 25% discount would apply. After entering the FREUDI08 code it only deducted 10% off the stated sell price.
    • Andrew Benedetto
      • 1071
      • SoCal, USA
      Send an email to CS or call they should honor the 25% off. You can print screen or print as a .pdf for proof. A while back similar problem like this occured to me and they did give the discount.
      Andrew
        Ordered some router bits, and saw that the total only reflected a 10% discount, so called CS before finalizing the order... The gal checked everything out and said to go ahead and enter the order while she was on the line and she would adjust it on the fly. Well, it didn't work, and the order went through and on down the wire to the CC company, so she had to figure out the discount on her own, and then issue a credit to the CC. Sometimes it seems like they would wake up and realize just how screwed up it can get, and how much trouble it causes them, the way their system operates nowadays... Oh, well.
        • thallikar
          • May 2006
          • 199
          Why not buy the SD208 for just a few bucks more?
          • mpauly
            • 337
            • NJ
            If you're using it on a BT3x, many have reported clearance issues with the larger diameter. If using a larger saw, agreed, go for the sd208.
            Michael
              Correct. In the BT3K, you can't stack all the chippers on the 8" dado set. Don't fit. Unless you need 2" deep dados, a 6" works just fine.
              • jobole
                • 47
                Fixed checkout price
                Discount now shows correctly in checkout..... $63.74
                • mschrank
                  • Oct 2004
                  • 1130
                  • Hood River, OR, USA.
                  And looks like Amazon fixed it so that you don't even need to enter a code...just drop a Freud blade in your cart and it'll get discounted 25%.
                  • Knottscott
                    • 3815
                    • Rochester, NY.
                    • 2008 Shop Fox W1677
                    Now that the 25% discount is working properly.... the Avanti TK406 60T blade is at ~ $26 shipped, and the TK306 40T is ~ $22 to your door....not too shabby if you're bargain hunting....
