Jointer & Planer Knife Pre-Stock Sale
  • ryan.s
    • 785
    • So Cal
    Hi Brian - I'm ready to place my order but just wanted to double check the size for the Craftsman 21706 6 1/8 Jointer.
    STB6125625093 Weight 1.00 lbs Shank 1/2" Qty Per Set 3 Length 6-1/8" Width 5/8" Thickness 3/32"
    Thanks!
    • sweensdv
      • 2871
      • WI
      • Baileigh TS-1040P-50
      Originally posted by jcmchris
      ........... Also I am not sure what set would fit my 6" Jet jointer the 6-1/16" X 13/16" X 1/8" or the 6-1/8" X 5/8" X 3/32".
      I'm wondering the same thing as I have a Jet JJ-6CS jointer. According to my Jet catalog the 3 Jet 6" jointers all have different sizes of knives. The JJ-60S has 6-1/16x5/8x1/8 knives, the JJ-6CS has 6x5/8x1/8 knives and the JJ-6CSDX has 6x7/8x3/64 knives. So it appears that none of the sets Brian listed are an exact match for any of the Jet 6" jointers.
      • pecker
        • Jun 2003
        • 388
        Thanks!
        I have that model, and I measured one of my "used" knives this morning. It measured 6 1/8" x 1/8" x 11/16". I emailed Holbren to ask if he'd get that size, but haven't heard back yet.
        I suppose anything close would be useable...you'd just have to reset the outfeed table height to accomodate the new blades.
        • ryan.s
          • 785
          • So Cal
          I ordered a set a few minutes ago. Hopefully if there is a better match for the 21706 Brian will be able to change the order. Thanks for posting the measurements. I checked the user manual and the sears site but wasn't able to find any specs.
          • MBG
            • Apr 2003
            • 945
            • Chicago, Illinois.
            I have the jj-6os and have used Freud 6x5/8x1/8. I have also seen some use the 6-1/16"x5/8x3/32".
            • Holbren
              • Oct 2004
              • 705
              • Heathrow, FL.
              Stupid question but the are the knives pre-sharpened. Also I am not sure what set would fit my 6" Jet jointer the 6-1/16" X 13/16" X 1/8" or the 6-1/8" X 5/8" X 3/32".
              They are presharpened.
              As for machines, I don't have a machine list so I have to go to the web and check. If the manufacturer of the machine doesn't list size, I have no way of knowing.
              I am pretty sure I have every 6" knife on my list that is available to me. I don't know how each machine would react but I'm sure you can get away with a knife 1/16" off in a lot of cases.
              I'm thinking the manufacturers messed around with the knife size to make sure you came to them when you needed a new set.
              Brian
              www.holbren.com
              • big8pt
                • Aug 2007
                • 15
                • Woodbridge, VA
                • PM2000 3hp
                Thanks Brian (Holbren) - just placed an order.
                  Brian,
                  I found some of the knife information via Amazon especially for the Delta JT since my local Lowe's stopped carrying it (thought I think the display was still there).
                  And are carbide blades for your shelix heads you carried, in this?
                  Thank you!
                  • cork58
                    • 365
                    • Wasilla, AK, USA.
                    Knife
                    Thanks for shipping to Alaska freight free! You are one of the very few that will honor free shipping to Alaska. I just ordered 2 sets for my jointer, then looked around your store. WOW! OH MY! OH LOOKIE HERE! I bookmarked your store and am making a wish list for next year. Whiteside OH MY!!!! Norton OH MY! You will see me soon in the active members list. Whiteside first, well maybe............
                    Thanks for the tip about the knives.
                    Cork
                    Cork,
                    • Holbren
                      • Oct 2004
                      • 705
                      • Heathrow, FL.
                      #25
                      [quote=LinuxRandal;312790]And are carbide blades for your shelix heads you carried, in this?[quote]
                      Just the knives on the link, no Byrd stuff. I can get the carbide straight knives too but they are about 4X more $$ and not worth it IMO because of issues with wood. If they get chipped, they are garbage.
                      Brian
                      www.holbren.com
                      • Holbren
                        • Oct 2004
                        • 705
                        • Heathrow, FL.
                        #26
                        [quote=LinuxRandal;312790]Brian,
                        I found some of the knife information via Amazon especially for the Delta JT since my local Lowe's stopped carrying it (thought I think the display was still there)[quote]
                        Is that the JT360? Can you share the info so I can help somebody else.
                        Thanks
                        Brian
                        www.holbren.com
                          [QUOTE=Holbren;312810][quote=LinuxRandal;312790]Brian,
                          Thanks
                          Showing my reasoning, search parameters
                          I went to Amazon and typed Delta JT360. On its page they had a link for blades Delta 37-658. I then verified (googled) what I remembered reading, the JT was a renamed jointer.
                          Then I clicked on the user reviews as I find most unpublished useful tidbits listed there.
                          they are 6.125"L x .6"H x .095" is the quote from the review.
                          Hope this helps!
                          • DaveStL
                            • 100
                            • St Louis, MO, USA.
                            • Jet 10: Xacta RT
                            #28
                            Thanks!
                            I have that jointer, just measured it: 6-1/8 X 5/8 X 1/8. Sent a PM to see if they're available, but probably too late. Oh well, add it to the knowledge base, anyway. Definitely a nice deal.
                            Dave
                            • boblon
                              • 727
                              • Florida, USA.
                              #29
                              Yeah, I've not been around for a few day. Am also sorry I missed this deal.
                              Oh well,
                              BobL.
                              • Holbren
                                • Oct 2004
                                • 705
                                • Heathrow, FL.
                                #30
                                I extended it another day for the day late crowd.
                                Brian
                                www.holbren.com
