Porter-Cable 7518 3.25hp router: $275
  • GaryA
    • 365
    • Tampa, FL, USA.
    Been keeping an eye on this router for a while since I got my (still boxed) Bench Dog CI table & lift. Saw this deal at Coastal:
    http://www.coastaltool.com/cgi-bin/w...ort/pr7518.htm
    $275 seems to be a good deal (Amazon best is $319). Have you guys seen better for this router? Coastal reputable? This appears to be new, not refurb (??)
    Gary
  • affyx
    • Oct 2007
    • 69
    • Mechanicsburg, PA
    • BT3000 (sold), ShopSmith (bought then sold), BT3100 (just bought on CL)
    Coastal is the goods
    Originally posted by GaryA
    Coastal reputable?
    I recently purchased a Kreg Jig from Coastal - the experience was great. I was worried about them too and had a colleague from the Hartford area visit the store for me to make sure they were legit before I placed my order.
    Went with cheapest UPS ground and still got it the next day! (CT to PA)
    Good luck with your new router...
    JC
    LumberJocks: http://lumberjocks.com/affyx
    "I lost my little saw and now I can't cope."
    • dabeeler
      • 51
      Would you be interested in a Freud 3 1/4 Plunge for $125 shipped. If so then check out http://www.hartvilletool.com/.
      • Jeffrey Schronce
        • 3822
        • York, PA, USA.
        • 22124
        That is a good price. $250 is the cheapest I have seen it and that was a HDT special. The Milwaukee is just as good, if not better and can regularly be had for around $250. Man, I wished I knew if that Jessem/Milwaukee motor unit is ever going to ship from Amazon. If not I would likely pick this up.
        dabeeler, the Freud is a plunge router which has a motor that can not be removed and put into a lift as described by Gary.
        • GaryA
          • 365
          • Tampa, FL, USA.
          Yep - exactly - I've got a Hitachi M12V2 now, but I can't get to the bits above table because its a plunge...
          Jeffrey - I thought there was a down side to the Milwaukee vs the PC in the BD Pro-Lift...no? ALso - whats the Jessem/Mil unit you refer to? Thanks
          Gary
          • Jeffrey Schronce
            • 3822
            • York, PA, USA.
            • 22124
            Milwaukee is slightly smaller in diameter thus the included shims must be used. Jessem/Mil unit is Milwaukee motor modified by Jessem to include VS and power switch that can be mounted away from router.
            • jtrcy
              • Jan 2005
              • 182
              [/QUOTE]
              I recieved my Milwaukee/Jessem moter last week from Amazon. Picked up the completee Jessem setup - moter, mastRlift, stand, phenolic top and fence. The only thing I haven't recieved yet is the fence.
              Think the MastRLift ended up costing me $145, normally $269.00 bought each item seperate with a dremel or B&D tool to get the 20% and the 25% discount on each Jessem item.
              JT
              • Jeffrey Schronce
                • 3822
                • York, PA, USA.
                • 22124
                JT
                Yes! And you ordered it back when the others did? Around September 29th?
