Bench Dog 40-031 CI Table (or lift)- Amazon $185 with promos!!!
  • GaryA
    • 365
    • Tampa, FL, USA.
    It's baaaack!! This is an incredible deal. I know Jeff got something similar a while back and I've been keeping an eye on these for a while. Amazon is running both the 20% off with qualifying power tool PLUS another 25% off with promo code and FREE shipping!
    So...I just ordered: the Bench Dog cast iron extension router table AND the Prolift Max router lift. You add a cheap power tool (I found the Dremel engraver 290-01 for $15.86 - GMC sander was $24+ this time), and apply the "BIT20OFF" code through checkout, and here is how each deal came out:
    Bench Dog 40-031 ProMax Cast Iron Router Table Extension
    Item(s) Subtotal: $324.85
    Shipping & Handling: $40.78
    Super Saver Discount: $-40.78
    Shipping Savings: $0.00
    20% Off Accessories: $-61.80
    Promotional Certificate: $-77.25
    Total Before Tax: $185.80
    Estimated Tax: $0.00
    Grand Total: $185.80
    Bench Dog 40-016 ProLift Max Router Top-Adjustment System
    Item(s) Subtotal: $341.31
    Shipping & Handling: $21.90
    Super Saver Discount: $-21.90
    20% Off Accessories: $-65.09
    Promotional Certificate: $-81.36
    Total Before Tax: $194.86
    Grand Total: $194.86
    Now I just need a great deal on the PC Speedmatic 7518...I don't think my M12V2 is going to work too well in it....
    Good luck!
    Gary
  • Cheeky
    • 862
    • westchester cty, new york
    • Ridgid TS2400LS
    http://www.amazon.com/Bench-Dog-40-0...0140955&sr=8-1
    http://www.amazon.com/Bench-Dog-40-0...0141034&sr=1-1
    Pete
    • foneman
      • 235
      • kansas, USA.
      Gary,
      Thanks for the posting, I have been wanting one of these!!
      John
      john
      • GaryA
        • 365
        • Tampa, FL, USA.
        Thanks Cheeky (duh!)
        Me too John....I'm stoked about the deal! (wife, not so much so)
        Gary
        • kmk
          • 415
          • .Portland, Oregon
          what is the cheapest power tool?
          • GaryA
            • 365
            • Tampa, FL, USA.
            http://www.amazon.com/Dremel-290-01-...0142110&sr=8-1
            $15.86 (unless someone can find a cheaper one...but I looked for a while)
            Gary
            • p8ntblr
              • 921
              • So Cal
              • Craftsman 22114
              OOh good fine. Cheapsest one I found was the GMC mouse sander for $24.
              I just ordered a similar combo but opted for the Mast-R-Lift. I've heard good things about both lifts but the Jessem is about $75 cheaper. The only one that seems to be significantly better is Woodpecker's Quick-Lift which Amazon doesn't carry.
              Why did you go with 2 separate orders though?
              -Paul
              • Pakaderm
                • 116
                Would this work well as a first router table for bt3100 owner?
                -Pak
                • GaryA
                  • 365
                  • Tampa, FL, USA.
                  Two seperate order just because you usuallu can't apply the discounts to multiple products on a single order....didn't try it, but thats how it usually works.
                  Pak - this is more for bolting on to a larger cabinet saw - I don't think you'd find an easy way to make it work with the BT3100
                  Gary
                  • gatordogs2
                    • Aug 2007
                    • 94
                    • So.Florida
                    • 22114 soon
                    Newbie Q who knows very little about TS's and even less about Routers.
                    I recently purchased a Craftsman 22114, Biesemeyer Fence, and Bosch 1617 Router (craftsman version).
                    What do I need to hook up this router under the Biesemeyer table extension at the end of my TS?
                    A lift, insert plate, etc?
                    What if there is no tomorrow?....there wasn't one today!
                    -Barry
                    • cyberodie
                      • 30
                      • Colorado
                      Newbe Q # 2. I don't know anything about lifts. I ordered the Bench Dog router table top, and a M2V2 that I just received yesterday. I was hoping to use the M2V2 as a dedicated table router. Why won't this lift work with the M2V2?
                      Thanks.
                      Kevin
                      • Jeffrey Schronce
                        • 3822
                        • York, PA, USA.
                        • 22124
                        Thanks.
                        Do you mean M12v2?
                        Look at the router. Look at the lift. See?
                        • cyberodie
                          • 30
                          • Colorado
                          Never mind. Went to the bench dog site and looked at the manual and it says it doesn't work with plunge routers.
                          Kevin
                          • Jeffrey Schronce
                            • 3822
                            • York, PA, USA.
                            • 22124
                            What do you need to mount router under Biesemeyer table? About $1 worth of screws and drill a hole through the table for the bit opening.
                            Or you could route an area out and put in a plate.
                            Or you could route an area out and put in a lift (which includes plate).
                            IMHO BD CI lift is too heavy for the Biesemeyer table unless you put a lot of support in it. Those Bies tables arent the flattest things in the world to begin with.
                            You have a ton of options. Now how are you gonna connect a fence?
                            Personally, I think you have two options. One - you are a confessed newbie make it simple and cheap as you will out grow it. Or Two - buy the BD CI table and BD CI lift and be done with it.
                            • Jeffrey Schronce
                              • 3822
                              • York, PA, USA.
                              • 22124
                              -Pak
                              The table and lift probably weigh more than an entire BT3. You should build a free standing stand for the table.
