20% Off At Amazon w/ Power Tool Purchae
  • Jeffrey Schronce
    • 3822
    • York, PA, USA.
    • 22124
    The deal details is located in the thread about the Kreg K3.
    It looks like the discounts are working properly now. I was having problems getting 20% off to apply to Bench Dog lift with purchase of GMC sander for around $10. Today it is working. You can also use the promo more than once if you like. Looks like the GMC sander is the lowest priced item to qualify one for the 20% off accessories.
  • gwyneth
    • 1134
    • Bayfield Co., WI
    I've been wondering about that. Do you mean they'll give you the 20% off several accessories if you buy them with a qualifying power tool? The verbage "and an accessory" makes it look like the discount will be applied to only one.
    Or does 'more than once' mean you can buy another power tool and another accessory?
    • Jeffrey Schronce
      • 3822
      • York, PA, USA.
      • 22124
      CAUTION: It will only apply to the lowest priced accessory. Example you buy $279 Bench Dog lift and $20 Bench Dog feather board you will get 20% off the $20 item. Therefore it makes sense to buy the higher priced item with the sander, then place a second order for smaller items.
      • gwyneth
        • 1134
        • Bayfield Co., WI
        Excellent caution. Maybe everybody's mental appreciation somewhat offsets all the frustrating time and energy you spent dealing with this somewhat goofy offer.
        to Jeffrey!
        • stormdog74
          • Mar 2007
          • 426
          • Sacramento, CA
          While that is what happens, that shouldn't be the case - see below where it says all:
          "The discount will be reflected on the final order checkout page and will be allocated to all participating items in the Shopping Cart."
