Peachtree Alignment critter
  • MikeMcCoy
    • Nov 2004
    • 790
    • Moncks Corner, SC, USA.
    • Delta Contractor Saw
    I have no interest but just got an email from Peachtree with this guage and seemed (??) a good buy.
    A-LINE-IT BASIC SYSTEM
    UPGRADED WITH SMART MITER BAR
    50% Off Regular Price of $79.99
    E-Direct Price $39.99
    Save $39.99
    The A-Line-It Basic was selected as the "Top Value" in the WOOD Magazine article that compared woodworking machine alignment tools.
    Last edited by MikeMcCoy; 04-27-2007, 09:15 AM. Reason: http://www.ptreeusa.com/edirect_042707.htm
  • Cike
    • 38
    I got the same email, and was wondering if I should be interested. How much value would this bring (even at $40) versus aligning with a square (for a hobbyist)?
    C
    • MikeMcCoy
      • Nov 2004
      • 790
      I use a dial guage already. One quick advantage to a guage over a square is knowing that saw blade tooth you're checking is actually being checked at the tooth. Even as just a hobbyist, I don't mind wasting wood due to my own misjudgement but I would rather not waste it due to something as simple to check as alignment.
      • Holbren
        • Oct 2004
        • 709
        • Orange City, FL.
        I used something similar I borrowed from a friend when I had a cabinet saw. Found it very useful for the fence more than the saw blade but did check the blade too. Being a fence is supposed to be kicked out about .005" or so at the back, it's hard to get that accurate with a square.
        Brian
        www.holbren.com
        • p8ntblr
          • 921
          • So Cal
          • Craftsman 22114
          I wasn't on their mailing list so I didn't get the email. I looked on their site but it's still listed as $79.99. Did they send you some type of special link or a coupon code to use? thanks
          -Paul
          • MikeMcCoy
            • Nov 2004
            • 790
            P8 - I copied and pasted the link in the edit portion of my original post and it comes up $39. Try that since the link was from the email.
            • p8ntblr
              • 921
              • So Cal
              • Craftsman 22114
              I don't see the link
              -Paul
              • MikeMcCoy
                • Nov 2004
                • 790
                • thrytis
                  • 552
                  • Concord, NC, USA.
                  • Delta Unisaw
                  Useful and i'm sure well made, but you can pick up a dial indicator pretty cheaply (i think HF goes on sale for about $7) and make the cross piece/miter bar out of some scrap wood and a bolt, nut, and washer. If you want to use it for your jointer, you'll also need a couple of magnets. Just an option for someone looking for a much cheaper solution.
                  Eric
                  • geeoh
                    • 80
                    • Mid Maryland
                    • Delta Contractor
                    Out of Stock
