Delta 50-345 mobile base.
  • GPA61
    • 712
    • Rancho Cucamonga, CA
    • BT 3100 & JET JWTS
    Delta's universal mobile base is on closeout at Lowe's. Regular price was $59.99 and I paid $29.99 today. Lowe's sku #77260. If you are in the market for one, I thought you'd like to know.
    Claudio
  • ScottJ
    • 65
    • SoCal, USA.
    Claudio...
    Can you post a scan of your receipt? I checked locally, but the in-store price was $59.98. Thanks!
    ...Scott
    • sailtravis
      • Sep 2005
      • 13
      • Wimberley, Texas
      • BT-3100
      Thanks for the heads up. I bought the last two at the Bee Caves store in the Austin Area. Really needed them.
      Rusty
      • GPA61
        • 712
        There you go Scott. Be sure you tell them it is a non-stock item.
        Claudio
        • ScottJ
          • 65
          • SoCal, USA.
          Thanks, Claudio!!!
          I took in a copy of your receipt to my local store and walked out with a Delta 50-345 mobile base. Relatively painless process, since your receipt was so current and relatively close to my store.
          ...Scott
          • twilson
            • 18
            Went by my local Lowes (Greensboro, NC) today at lunch time and saw that they had moved their remaining stock of these mobile bases to the clearance table. I bought one for $29.99. They had (2) remaining.
            • Greg in Maryland
              • 250
              Thank you Claudio!
              I have been eyeing this thing for a while, but $60 plus tax is a bit more than I wanted to pay. Using your receipt worked like a charm.
              One question to those more experienced than myself, what is the best material to use for the rails? The instructions call for "hardwood." I would estimate that I'll put a 100 to 150 pound drill press on the base.
              Thanks.
              Greg
              • GPA61
                • 712
                Hi Greg,
                I used mine for the drill press also. Since it is such a short base I used pine for the rails. Mine is a pretty big drill press too, weighs about the same as yours. Now if you were going to use if for a heavy saw with considerably longer rails, I'd use the hard wood.
                Only time will tell if it will hold up, but I don't foresee a problem.
                Claudio
