Shamelessly stole this from clearanceman at FW...
IRWIN 14082 Marathon 12-Inch 72 Tooth Satin Smooth Finish Circular Saw Blade
Enter code 2OOFFPTA at checkout for $4 off (20% actually)
So, I'm getting this 12" 72 tooth blade for my Bosch 4212L miter saw, since I only have the general purpose (40T?) blade.
I also only have the general purpose 36T that came with my BT3100. If you were going to buy one more blade for this table saw, which one would it be?
Also $16 - IRWIN 14074 Marathon 10-Inch 60 Tooth Trim & Finish Circular Saw Blade
$26 - 20% - IRWIN 14076 Marathon 10-Inch 80 Tooth Satin Smooth Finish Circular Saw Blade
Are these hot prices? These blades seem to get good reviews. Anybody have opinions?
....hate to dampen your enthusiasm, but I'd suggest shying away from the Marathon series altogether and either spend a bit more to get more, or try taking a chance on a different series. Irwin's "Woodworking" series is (or was) an excellent precision line that was made in Germany by Leitz...identical to the high end H.O. Schumacher & Sohn blades with laser cut bodies and nice carbide tips. The Marathon blades are a different animal ...very average Chinese made entry level homecenter/DIY grade blades with stamped steel bodies and thin carbide. They'll cut, but won't rival the better blades, won't eclipse many other decent blades, and likely won't hold an edge for too long. The carbide is small enough that they won't hold up to too many sharpenings either, so in the long run the hot price cools down alot.
