Forrest WWII $71.99!
  • BigguyZ
    • Jul 2006
    • 1818
    • Minneapolis, MN
    If I have a TS and RAS, wouldn't I be better suited getting a good quality freud or other ripping blade on the TS, and keeping my 60T Dewault on my RAS? I currently have a 50T freud on the TS, and ripping HW seems to give it more trouble than it should...
    Or would I still be better off getting the WWII?
    If not, then is there a thin kerf frued ripping blade someone would recomend? my other blades are TK.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      Originally posted by leroy37921
      Thanks, I just canceled and reordered.
      Any ideas for a good 10" miter saw blade?
      "Ideas"...yes...."Good ideas"...who knows!
      The Forrest Chopmaster, Ridge Carbide, Infinity, LU91R010, LU96R010, LU85R010, DW7647 ...
      http://www.epinions.com/content_245518143108
      • Knottscott
        • 3815
        • Rochester, NY.
        The LU87 is on sale for ~ $28 shipped...nice blade...TK. I'd definitely put it on the TS and rip with that. Keep the 50T for general purp stuff.
        • Tundra_Man
          • 1589
          • Sioux Falls, SD, USA.
          Thanks for the update. I sprung for one.
          Terry
          • BigguyZ
            • Jul 2006
            • 1818
            • Minneapolis, MN
            I looked for that at Amazon, but I couldn't find that or any TK ripping blade...
            • JSCOOK
              • Sep 2006
              • 774
              • Kitchener, Ontario, Canada
              • Ryobi BT3100-1
              FWIW, on my miter saw I'm using a Freud TK806 10" 80-Tooth Ultra Fine Crosscut Blade and get excellent results!
              • Knottscott
                • 3815
                • Rochester, NY.
                http://www.amazon.com/Freud-LU87R010.../dp/B0000225UH
                Here's one that's new. I haven't given it a direct spin yet, but Messmaker is reporting good results from his DW7150PT which is from the same series, and I've gotten great results from my series 40 DW7124TK....for ~ $20 shipped, it might be worth a shot. The most obvious difference between this and the LU87 is the tooth grind. The DW is an FTG, which is a bit more efficient. The LU87 is an ATB, which is a bit cleaner cutting.
                http://www.amazon.com/DEWALT-DW7124P...8?ie=UTF8&s=hi
                Let us know if you give the DW a try.
