Model # 93760 28 degrees which accepts both clipped and full head nails orig $199 , normal $99 now $79. Is this decent for occassional hobbyist use? The 94000 (clipped head only)on sale now w coupon @ $49 is not available in store. Is it worth ordering mail order? Thanks
HF Framing Nailer sale
There are older threads on this matter. Basically if you plan to use it for construction you should check with local builders/inspectors and find out which one is preferred by building codes in your area.
Also, make sure you have a reliable supply of nails. You may find that certain degree nails are harder to find and/or more expensive.
