HDT - (1) Eurekazone Ez Smart 100" w/ Makita Saw
  • Jeffrey Schronce
    • 3822
    • York, PA, USA.
    • 22124
    From HDT email :
    We have a lot of 10 SGS-1 Eurekazone Ez Smart 100" Guides Systems with Makita 5007FK's. These will be a limit 1 to our non-reseller customers only please (I know who the resellers are ). I know this is not many to go around , but these 10 are all we have and the price is right - $200 and $9.75 shipping via UPS Ground. There will be no backorders or rainchecks. These should be in stock around 10:30 am eastern time - this is when the UPS man will be here with the 5007 saws.
    Thank you !
    Mark Strickland HDT
    PS - Anyone have an arcade cabinet for sale cheap within a couple of hours drive of the Asheville,NC area ? - let me know
  • Stormbringer
    • 1387
    • Floral Park, NY
    • Bosch 4000
    EurekaZone ststem @ HDT (Only 10 available)
    Eurekazone SGS-1 & Makita 5007FK Combo (SGS-1COMBO)
    These should be available around 10:30 am eastern
    HDT Combo Deal Includes The Eurekazone SGS-1 100" EZ Smart Guide System and Makita 5007FK 7-1/4" Circular Saw Kit
    Limit 1 On This Special - No Non-Warranty Returns (ie. no returns because you didn't like it,the saw doesn't have a brake,the saw doesn't have a dust chute,it is not a Festool,etc)
    The SGS-1 description from Eurekazone.com -->
    ..combining a Radial Arm Saw, Panel Saw, Table Saw, Straight Line Rip Saw, and a Jointer into one tool and at the same time, surpass their limitations. What you have now is one tool that can do almost everything that all the other tools can do and everything that you wished that they could do....Easier, Faster, Safer, and better than ever before.
    What you have now is "ALL THE RIGHT TOOL" for less than the cost of an expensive saw blade.
    Now imagine what you can do with this tool.
    * Modular-infinite-self-aligning-extendable with Zero Play....patents Pending
    * Bidirectional with 2 Zero positioning, replaceable, anti-chip edges.....patents Pending
    * Zero clearance insert for the wasted side of the cut ....patents Pending
    * Integrated positioning and measuring system. (the Repeater) ....patents Pending
    * And a few hundred more patent claims.
    The 5007FK circular saw kit --> * LED light switch operates independently from the trigger
    * Flat motor housing design increases stability when changing blades
    * Powerful 15 AMP motor for a high power-to-weight ratio
    * Heavy gauge aluminum wraparound base
    * Ball bearing construction for a longer tool life
    * Bevel cuts 0-45° with a 45° cutting capacity of 1-3/4"
    * Conveniently located shaft lock for easy blade replacement
    * Technologically advanced centrifugal fan and baffle for efficient cooling of the motor
    * AC/DC switch allows for use with alternative power sources
    * Includes premium 7-1/4" x 24T carbide-tipped blue-coated MForce™ blade for faster, smoother cutting in pressure treated lumber
    * Double insulated
    Product Reviews :
    Write a review
    Miscellaneous :
    • jarhead
      • 695
      • Boynton Beach, FL.
      Kept hitting the refresh button furiously starting 10:29am and was able to get one.
      • siliconbauhaus
        • Dec 2006
        • 925
        • hagerstown, md
        nice deal you got there mate
        パトリック
        daiku woodworking
        ^deshi^
        neoshed
          That was quick. I considered getting one to give my dad (he's borrowed mine), but I am waiting on the new style table, then I give him my spare rails, and right handers saw.
          Still watching for a good deal on a 10" saw, to really see if I can replace the tablesaw (can now for the types of projects I have been doing, but want to get into some other stuff).
