Drawer slide on clearance @ Lowes store
  • dfstrasser
    • 15
    • North Augusta, SC, USA.
    I would have bought some but they were all gone at my Lowes.
    • Woodwerker
      • 490
      Originally posted by jgscott987
      What in the world is the rationale for this kind of stuff. Lowes and Home Depot both do it. They put some riduclously low price on a staple item that they will obviously continue carrying.
      I put a sprinkler system in my yard a few years ago. The sprinkler control wire normally sells for $20 for a 100' roll. They dropped the price to $1.99 for a couple of weeks, fortunatly right at the time I needed it, saving me over $150.
      You guessed it, they still sell the exact same wire, same brand, etc., but the price is back up to $20. I'll wager that the exact same thing will happen with the drawer slides. They will continue to carry the exact same brand as before.
      I can see putting a really low price on some item you want to get rid of, but to blow out items you fully plan to contine carrying just doesn't make any sense.
      (Not that I mind that they do it! )
      Got some too... only had 16" but I got 12
      JG to answer your question, there could be many reasons for the inventory dump, things such as a minor change in the safty instructions in the manual to conform to a new law. Or a change in packaging. How they arrive at a price beats me. But I'm sure its related to cost of the item, vs. the amount that the supplier will eat...
      Like you said, "not that we mind that they do it "
      Every tool you own is broken, you just don't know it yet :-)
      • onedash
        • Mar 2005
        • 1013
        • Craftsman 22124
        I wasn't planning on using slides but I guess I will have to check to see if they have em on clearance here. If they do I might have to redesign my project a little bit.
        • Richard
          • 89
          If the almond K&V aren't stickered at the prices I quoted I would be very surprised. Evidence supports the notion that this is a nationwide clearance.
            Checked 2 Lowe's in Austin and called the one in San Marcos tonight for 22" slides...NADA!
            • RED2GAUGE
              • 26
              • Santa Clarita, CA, USA.
              thanks for the tip. I got only 5 22" in the Santa Clarita store and i believe i had the last of it. All the slides were gone.
              • mikebanks
                • 159
                • lowell, ma, USA.
                • 2 BT3000 and 2 Delta 34-400's
                Woburn MA store
                I got a few last friday. 12 550's and 6 400's.
                Went back yesterday when someone mentioned check the shelving above the racks for unopened cases.
                Got 6 more 400's.
                Maybe...........
                • xli1
                  • May 2006
                  • 151
                  • Big Boston Area
                  • Ryobi BT3100-1
                  #23
                  I forgot to mention that the socket for using with these drawer slide is also on clearance @ 44 cents each (regular $1.76). I picked a dozen for my projects which save me some effort for building the support.
                  http://woodworkingdiy.googlepages.com
                  • radhak
                    • 3061
                    • Miramar, FL
                    • Right Tilt 3HP Unisaw
                    #24
                    what socket? where do you need those?
                    - Aristotle
                    • xli1
                      • May 2006
                      • 151
                      • Big Boston Area
                      • Ryobi BT3100-1
                      #25
                      Here is what I was talking about. You use this to mount the slides rear end to the cabinet back instead of side, which in most cases you will need a spacer. You can find more info here. I just finished using these sockets to mount 4 drawers, it is easy to adjust, and seems pretty strong, I don't know if it will support 100 lb like the 1284 drawer slide promised, but should be good enough. It is 44 cents a pair.
                      • BigguyZ
                        • Jul 2006
                        • 1818
                        • Minneapolis, MN
                        #26
                        I think he means the bracket that lets you easily use the slides for face frame construction without the need for a spacer block.
                        • radhak
                          • 3061
                          • Miramar, FL
                          #27
                          Hmmm...so i'd need to use two of these, one at the back and another at the front to hold the cabinet slide up? And it can only work with with-face-frame cabinets, right (as BigguyZ has indicated)?
                          - Aristotle
                          • xli1
                            • May 2006
                            • 151
                            • Big Boston Area
                            • Ryobi BT3100-1
                            #28
                            Yes, it only works for cabinets with face frame, but you do not need it at the front, it is only used at the back. The drawer slide front is directly mounted on the face frame.
                            • whitedogone
                              • 46
                              #29
                              I stop by the local Lowes nearly everyday waiting for them to mark down stuff. It seems like they lag behind most as far as when they do the markdowns. And most of the time they don't take as much off as other stores. Finnally saw these today. Got 6@16", 3@18, and 3@20. Not the lengths I would have wanted but the price couldn't be beat. Less than $10.00 out the door. Thanks OP! WDO
                              • xli1
                                • May 2006
                                • 151
                                • Big Boston Area
                                • Ryobi BT3100-1
                                #30
                                I seems to figure out that if the item is on clearance nation wide, when you scan the item, the price should be what was marked. If it is only a local store clearance, then the scanned price will still be the original price and will need the cashier's manual ajustment. Let me know if I am wrong.
