Denali 3.6V Lithium Ion Cordless Screwdriver Kit
  • ryan.s
    • 785
    • So Cal
    Seems like a good deal based on the postive ratings. Anyone try one of these?
    http://www.amazon.com/exec/obidos/AS...etsreviews5-20
  • Andrew Benedetto
    • 1071
    • SoCal, USA
    Price was $20 for a while. Remember no shaft lock or clutch so you still may need a screwdriver for fastening and really too slow for much drilling.
    If it had a shaft lock then I would have bought it.
    Andrew
    • ryan.s
      • 785
      • So Cal
      Great point Andrew, thanks for pointing that out.
      • MilDoc
        This item does indeed have a spindle lock. Locks as soon as the power switch is released. No clutch tho'. But still a nice tool to keep in the house.
        • Andrew Benedetto
          • 1071
          • SoCal, USA
          I called and asked, they said that the plastic gears will tend to break if you tighten against the motor/trans. Not actually a spindle lock as such in design according to Tool Crib. tech.
          Paul ,are you sure that the manual says that is OK to do?
          Andrew
          • MilDoc
            Well, seems so, but not sure I would after your post. But LOML bought it for in-the-house use so I guess it's OK for that. Not for the sop tho'.
