Rebate on DeWalt Precision Trim Blade
  • Tree Farmer
    • 102
    I noticed the 10", 60-tooth DW3215 version of this blade today at Lowe's. DeWalt's offering a $10 mail-in rebate on the blade and if you use one of those special $10 off of $50 purchase cards that many of us received, then it's possible to get this blade for $20. (I never seem to walk out of Lowe's without spending $50!)
    I know this is not the exact same DW3215 Woodworking blade that DeWalt offered in the past, but at $20, doesn't it seem worth a try?
    Jon - From inside the artillery fan near Fort Bragg, NC
  • messmaker
    • 1495
    • RICHMOND, KY, USA.
    • Ridgid 2424
    Looks like a fine deal but you got me with the math. $50-$10-$10=$20??? Am I missing something?
    • Tree Farmer
      • 102
      Sorry....should have explained myself a little better. The retail price of the blade is $40. Well, how many of us go to Lowe's and buy only one item? I certainly don't (I'm buying a gallon of paint tomorrow). The rationale would be that you'd spend $40 on the blade and $10+ on anything else. The total purchase would pass the $50 mark and thus, you'd get the $10 off. In terms of the blade, it becomes $40 less the $10 coupon, the less $10 again when the rebate check arrives. Hence, the $20 final price.
      • messmaker
        • 1495
        • Ridgid 2424
        You are right about the one thing purchase. Never happens. Thanks for the clarification.
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          Do you know if it's still made in the UK? If so, I'd definitely say it's worth a try for that price.
          • Tree Farmer
            • 102
            Update
            Well, I pulled the trigger and bought this blade today. It's made in USA, has almost identical design characteristics compared to the Woodworking DW3215, and makes a very smooth cut. Only time will tell how it holds up, but I'm glad I spent the $30 (eventually $20) on it.
            • kramer katt
              • 375
              • SO CAL, USA
              • BT3100 and Craftsman 100
              Having the 10 of 50 card and needing a 10 inch finish blade, I got on of these.
              I am curious about the PT in the model number. Obviously not the TK for thin kurf and the teeth are quite wide. Not in the little Dewalt catalog that I have.
              Any one using this on a BT? or does it need more horsepower?
              kk
              --Albert Einstein
              • kramer katt
                • 375
                • SO CAL, USA
                From Dewalt site
                Sometimes you just can't see the obvious. Precision Trim
                FEATURES
                Premium Micro-Grain carbide produces ultra-sharp cutting edges that dramatically reduce splintering
                Precision Balanced, Laser-Cut Body provides extremely accurate cuts
                Exclusive Dampening Slots reduce vibration to enhance cutting accuracy
                Tough Coat Finish reduces heat, friction, and gum to promote blade life
                Catalog Number Description Diameter Teeth Arbor Size Hook Angle
                DW7118PT 8-1/2" 60T Fine Crosscutting Saw Blade 8-1/2 60 5/8 -5
                DW7124PT 10" 24T Fast Ripping Saw Blade 10 24 5/8 20
                DW7140PT 10" 40T Ripping / Crosscutting Saw Blade 10 40 5/8 20
                DW7150PT 10" 50T Combination Saw Blade 10 50 5/8 15
                DW3215PT 10" 60T Smooth Crosscutting Saw Blade 10 60 5/8 10
                DW3218PT 10" 80T Fine Crosscutting Saw Blade 10 80 5/8 10
                DW3216PT 12" 60T Smooth Crosscutting Saw Blade 12 60 1 -5
                DW3232PT 12" 80T Fine Crosscutting Saw Blade 12 80 1 -5
                DW7296PT 12" 96T Ultra-Smooth Crosscutting Saw Blade 12 96 1 -5
                BUT no spec on Kerf size??
                --Albert Einstein
                • Knottscott
                  • 3815
                  • Rochester, NY.
                  DW's numbering system would historically end in the suffix "TK" if it were thin kerf. I'd just assume that it's full kerf. You could always put a set of calipers on it.
